• Willkommen im Drohnen Forum von skyzr.com
    Eure Diskussionsplattform zu allen Themen rund um Drohnen. In unseren Foren findest du Hilfe zu Quadrocoptern und Multikoptern von unterschiedlichen Herstellern wie beispielsweise DJI, Parrot, Autel Robotics, Xiaomi und viele Mehr.
    Darüber hinaus erhälst du hier auch alle notwendigen Informationen zu Regelungen und Gesetzen sowie Tipps und Tricks um deine Drohne besser fliegen zu können .
    Wir wünschen euch viel Spaß beim Lesen und Mitdiskutieren!
New Inspire 2 Firmware Released (09/09/2020)
Dima
Administrator
Teammitglied
Registriert
16 Januar 2021
Beiträge
815
Drohne
DJI Mini 2, DJI Mini 4 Pro, DJI Mavic Air 2, DJI Mavic Pro, DJI FPV, DJI Avata
Quelle: https://forum.dji.com/forum.php?mod...ra=page=1&filter=typeid&typeid=560&typeid=560
Overview:
  • Date: 2020.09.09
  • Aircraft Firmware: V01.02.0500
  • Remote Controller Firmware: Ordinary Remote Controller: V01.01.0080
  • Cendence Remote Controller: V02.00.0190
  • DJI GO 4 app: iOS V4.3.37 or above, Android V4.3.36 or above
What's New?
  • Added support for Inspire 2 CINESSD 960GB (coming soon).
  • Optimized gimbal to reduce minor roll rotation when aircraft is flying left or right. Make sure to update aircraft and gimbal at the same time.
  • Optimized gimbal to reduce drift when there is no operation or when operation is stopped while aircraft is hovering. Make sure to update aircraft and gimbal at the same time.
  • Optimized power management during flight. Flight power is dynamically adjusted according to the battery temperature and remaining battery power, improving battery usage safety.
  • Fixed occasional issue: battery level displayed in app was higher than actual battery level, which lead to battery level dropping suddenly. Make sure to update all batteries.
Notes:
  • This firmware update is important. It fixes a critical issue where battery level suddenly drops during flight due to an inaccurate battery level calculation. Make sure to update immediately.
  • Once firmware has been updated, it cannot be reverted to an earlier version.
  • Inspire 2 CINESSD 960GB can only be used with CINESSD Reader UG2 (coming soon), while the CINESSD Reader UG2 can be used with all Inspire 2 CINESSD.
  • When using Inspire 2 with Zenmuse X4S/X5S/X7, it is recommended to update both at the same time.
  • Make sure both primary and secondary remote controllers are updated to the latest firmware to avoid control errors or camera and gimbal abnormalities.
  • If the firmware update fails, restart aircraft, remote controller, and DJI GO 4 app, then retry.
Zurück
Oben
